HDNamKhanh3
Chúng tôi cung cấp nhiều Amply Stereo Rotel chuyên nghe nhạc rất hay, đây là dòng Amply Stereo cao cấp, có đủ loại phù hợp với nhu cầu của khách hàng.
Nếu có nhu cầu xin liên hệ: HD Nam Khánh 0972.962.840 - 0936.509.688
Đ/c: Số 5, ngõ 210, Hoàng Quốc Việt, Hà Nội
Amply Rotel RA10
Giá cũ11.250.000 ₫
Giá mới(-1%)
11.150.000 ₫
Thông số kỹ thuật
Continuous Power Output:
40Watts/ch (20-20kHz, < 0.03%, 8)
Dimensions (W x H x D):
430 x 72 x 342 mm
Panel Height:
60 mm
Weight (Net):
5.9 kg
Amply Rotel RA 12
Giá cũ18.000.000 ₫
Giá mới(-2%)
17.590.000 ₫
60Watts/ch (20-20kHz, < 0.03%, 8Ω)
Power Consumption:
300Watts
Power Consumption:
0.5Watts Standby
430 x 92 x 342 mm
Weight:
8.02 kg
Rotel Integrated Amplifier RA-1570
Giá mới(-2%)
31.550.000 ₫
Thông số kỹ thuật:
Continuouspower output:
120 Watts/channel (20hz – 20khz, < 0.03% Thd, 8 ohms)
Total harmonic distortion:
< 0.03% at rated power (20Hz-20khz)
Frequency response:
10Hz-100kHz (+1, –3 dB)
Damping factor:
180 (20Hz-20khz, 8 ohms)
Input sensitivity:
2.25mV
Impedance:
68k ohms
Preamplifier output:
1.5V / impedance 470 ohms
Signal to noise ratio:
80 dB
Preout level/impedance:
1.2 V/ 470 ohms (at -20 dB)
USB/iPod:
WAV, MP3, WMA (up to 48kHz 16 bit)
Coaxial/optical:
SPDIF LPCM (up to 192kHz 24 bit)
PC-USB:
USB Audio Class 1.0 (up to 24 bit/96kHz)
USB Audio Class 2.0 (up to 24 bit/192kHz)
Power requirements:
230 volts, 50Hz
Power consumption:
400 watts
Power consumption:
< 0.5 watts Standby
431 x 144 x 350 mm
Weight:
13 kg
Amply Rotel RA11
Giá cũ15.750.000 ₫
Giá mới(-1%)
15.550.000 ₫
Thông số kỹ thuật:
Total Harmonic Distortion:
< 0.03% at rated power (20Hz-20kHz)
Intermodulation Distortion:
< 0.03% at rated power (60Hz:7kHz, 4:1)
Frequency Response:
Phono input 20Hz-15kHz, ±0.3dB. Line Level Inputs 10Hz-100kHz, ±1dB
Input Sensitivity:
Phono input 2.5mV. Line Level Inputs 150mV
Impedance:
Phono input 47 k Ω. Line Level Inputs 24 k Ω
Input Overload:
Phono input 180mV. Line Level Inputs 5V
Preamp Output:
1V
Impedance:
470 Ω
Bass / Treble:
±4 dB at 100Hz / 10kHz
Signal to Noise Ratio:
Phono input 80dB. Line Level Inputs 100dB (IHF “A” weighted)
Frequency Response:
10Hz-95kHz ±3.0dB (MAX)
Pre-out/Impedance:
1.2V/470V (at -20dB)
Decodable USB/iPod:
AAC (m4a), WAV, MP3, WMA (up to 48K 16bit)
Coaxial/Optical PCM:
LPCM
File Formats:
Real Audio, MP3, OGG Vorbis, WAV, AIFF and AU
Power Consumption:
220Watts Standby Power Consumption: 0.5Watts
430 x 72 x 342 mm
Panel Height:
60 mm
Weight (Net):
6.39 kg
Amply Rotel RA-1520
Giá cũ26.550.000 ₫
Giá mới(-15%)
22.500.000 ₫
Thông số kỹ thuật:
Power Configurations:
2 x 60 watts (20Hz-20kHz, <0.03%, 8 Ohms)
THD:
(20-20,000Hz) 8 Ohms, all channels driven < 0.03%
Phono Input:
20Hz-15kHz, +/- 0.2dB
Line Level Input:
10Hz-100kHz, +1, -3dB
Damping Factor:
(8 Ohms) 150
Line Input Sensitivity:
160mV / 24kOhms
Bass:
+3, +4dB at 100Hz
Treble:
+ 3dB at 10kHz
Line Input Overload:
5V
Phono:
2.4mV / 47kOhms
Phono Overload:
170mV
Preamp Output Levels / Output Impedance:
1V / 470 Ohms
S/N Ratio (IHF A):
>95dB
Power Consumption:
300 watts
432 x 92 x 364 mm
Weight (net):
7.8 kg
Hãy truy cập website hdnamkhanh.com để xem thêm rất nhiều amply nghe nhạc và thiết bị giải trí nghe nhìn khác.
Amply Rotel RA10
Giá cũ11.250.000 ₫
Giá mới(-1%)
11.150.000 ₫
- Tình trạngHàng mới
- Bảo hành12 Tháng
Thông số kỹ thuật
430 x 72 x 342 mm
Panel Height:
60 mm
Weight (Net):
5.9 kg
Amply Rotel RA 12
Giá cũ18.000.000 ₫
Giá mới(-2%)
17.590.000 ₫
- Bảo hành12 Tháng
Power Consumption:
300Watts
Power Consumption:
0.5Watts Standby
430 x 92 x 342 mm
Weight:
8.02 kg
Giá mới(-2%)
31.550.000 ₫
- Bảo hành12 Tháng
Thông số kỹ thuật:
Frequency response:
Damping factor:
Input sensitivity:
2.25mV
Impedance:
68k ohms
80 dB
USB/iPod:
Coaxial/optical:
PC-USB:
Power requirements:
230 volts, 50Hz
Power consumption:
400 watts
Power consumption:
< 0.5 watts Standby
431 x 144 x 350 mm
Weight:
13 kg
Amply Rotel RA11
Giá cũ15.750.000 ₫
Giá mới(-1%)
15.550.000 ₫
- Bảo hành12 Tháng
Thông số kỹ thuật:
Frequency Response:
Input Sensitivity:
Impedance:
Input Overload:
Preamp Output:
1V
Impedance:
470 Ω
Bass / Treble:
Frequency Response:
Pre-out/Impedance:
Decodable USB/iPod:
LPCM
File Formats:
Power Consumption:
430 x 72 x 342 mm
Panel Height:
60 mm
Weight (Net):
6.39 kg
Amply Rotel RA-1520
Giá cũ26.550.000 ₫
Giá mới(-15%)
22.500.000 ₫
- Bảo hành12 Tháng
Thông số kỹ thuật:
THD:
Phono Input:
Line Level Input:
Damping Factor:
(8 Ohms) 150
160mV / 24kOhms
Bass:
+3, +4dB at 100Hz
Treble:
+ 3dB at 10kHz
5V
Phono:
2.4mV / 47kOhms
Phono Overload:
170mV
1V / 470 Ohms
S/N Ratio (IHF A):
>95dB
Power Consumption:
300 watts
432 x 92 x 364 mm
Weight (net):
7.8 kg
- Tháo lắp tivi khi chuyển nhà bằng cách nào?
- Loa Boxt Q5s | Mẫu Loa Xách Tay Mới Hiện Đại, Pin Trâu
- Loa Acnos Ks362d | Loa Karaoke Xách Tay 100w, Pin Trâu, Giá Rẻ
- Loa Best Lux 16v: Sở Hữu Âm Thanh Chất Lượng, Thiết Kế Độc Đáo
